535d main bearings (pleuellager) green
  • ležaji.jpgkolbensch.jpgHello,
    I must preventively replace timing chain and I will change also main and rod bearings. At block is sign k*2222222 so it means I have green main bearings. I saw in TIS that measurment is:
    Stage 0 K2 (colour Green) mm 54.977 ... 54.983
    My qusetion is because there was no repairs or grinding so its std measurment. Can I use aftermarket Kolbenschmidt STD dimension witch is
    54.971 mm
    54.990 mm
