incoming air left and right from dashbord
  • Hello ..
    I have a F10 LCI from 2016 it is a Luxery line , my question is the turningwheels on airvents below the navigation to close and open the air are illuminated , but the ones on the left side and right side of the dashbord are not illuminated ??? Is this normal because the other buttons are all illuminated on my car . Can someone here confirm that on there F10 the turnigweels on the left and right side are illuminated?
    Thank you .
  • Ok problem solved, i took the right airvent out and there is no attachment for a power cable. So the right and left airvent cant be illuminated BMW is making some diference between some F10 lines because some are illumintated and some are not.
    Thank you everyone.
  • BMW is making some diference between some F10 lines because some are illumintated and some are not.
    As far as I know, the right and left airvents are illuminated with 4-Zone-AirConditioning. If you don't have 4-Zone, you don't have the illumination - there is no context with the different lines.
